Finished rib modification to the sub-panel by moving instrument panel support ribs in five inches. This allows up to a ten inch Skyview monitor to be placed in front of the pilot and co-pilot seats. It also leaves eight inches in the center of the panel for avionics. Moved the four screw holes on the instrument panel as well. The bottom holes were filled, but the top two holes will be inside the cut out area for even a seven inch monitor.
After the mod was completed I riveted one side of the sub-panel together. The sub-panel is now ready to be riveted in the aircraft. I will get that done next week. The next tasks I need to get done are system related.
I installed the tail wheel and rudder cables so I could start determining the rudder pedal to cable connections. I need to do some research on the geometry of the pedals, but I did fabricate the connectors.
