Workng to finish up a few items before attaching the canopy. Attached the canopy locks to the bottom of the canopy frame. I also drilled the attachment holes for the canopy guides. These two guides are designed to guide the canopy lock into place.
Next I will pull the canopy frame to install the canopy stops and rivet the sub panel in place. I am still deciding if I will have the roll bar fully installed before attaching the canopy. I do not believe it is necesary to have it bolted and riveted in place.
