Worked on the fine details of the latch fit. Sometimes you can't see the forest for the tress. I was working on the right, or aft, portion of the latch and could not get it to line up with the fuselagte skin. My wife said, "that fuselage curve is really a problem." Like I had realized the issue. I thought about that for a little bit and realized I need to fabricate a small curve in the mounting angle to match the fuselage. Now the fit is much nicer. I have about an inch along the bottom that needs to come out about .015."
