Scott's Aircraft Build Logs
Date:  4-28-2017
Number of Hours:  2.50
Brief Description:  Wing tips and lighting - 02
Other tasks completed today are"
1. Modified the wing tip riblet (mounts aft of the hinges) to fit the wingtip.
2. Counter-sunk the area where the hinge rivets are located. Riveted hinge to wingtip and then epoxied over the rivets on the top of the wing encasing them.
Spent a lot of time on the left wing as I had to figure out how all this would go together. The right one should go much faster.
