Scott's Aircraft Build Logs
Date:  7-23-2013
Number of Hours:  1.50
Brief Description:  fuel tank pickup - 02
Only had a little time to work on the project today. I focused on finishing the right tank fuel level probe and sealing the tank. I finished safetying the fuel pickup and reinstalled it in the fuel tank to check the probe placement. Everything is set for sealing. Tomorrow I will bend the fuel level probe for the RV-7 tank, attach it to the sensor and then seal the tank. Last step will be to pressure test the tank for leaks.
Finished IAW Vans SB
Placed back in the tank for fit
Fuel level probe
Fuel level probe
