First thing today I checked to ensure the aircraft was level. No photos, but I checked at the longerons on both sides and at the center section (F-704.) All were either level (0.0) or slightly off at 0.1. One tenth of a degree is level in my book. My next task was to measure the left wing to determine if the incidence is correct. This required constructing a 3 inch block to support the level as per the plans . I did use both a bubble level and a digital level to make the measurement and I measured the wing in four different locations. Two locations were level (0.0) and two were at 0.1. That is an average of 0.05 over the left wing's span. I believe that is level enough.
