Next step was creating the second set of aileron push tubes. They run from the bell crank out the wing to the aileron. The first set runs from the bell crank into the cockpit. The process used to rivet the first set of tubes was repeated for the second set. Imagine that! Although the rivet pattern is different (two instead of six) the idea is the same.
After finshing the second set (which you can barely see in image two and three) I inserted both sets into the wings. Wow, almost time to rivet the last wing skin. Let's see; run some more wiring and install the landing lights. That just about sums it up. The landing lights will be a bigger project as I have to modify the wing cradle. More later.
