Scott's Aircraft Build Logs
Date:  11-25-2013
Number of Hours:  5.00
Brief Description:  Flight controls and Dynon servo
Took all the pushtubes back out of the aircraft to check minimum thread distance. I shortened the forward tube by about 1/2". The aft tube had the bearings screwed all the way in, so I know I have a lot more than 1/2" in that tube. I will lengthen it tomorrow and get it ready to reinstall.
I installed the Dynon pitch servo bracket and attached the servo arm to the elevator bell crank. I still need to wire the servo to the DB9 connector, Once that is done I will torque and safety the three attaching bolts.
Forward pushtube
Forward pushtube
Pitch servo
Pitch servo
Pitch servo
Pitch servo
