Scott's Aircraft Build Logs
Date:  11-24-2013
Number of Hours:  3.00
Brief Description:  Flight controls
Fabricated the F-789 elevator pushtube that runs from the flight controls through the center section and connects the the pushtube running to the elevators. Started checking the rigging and getting the pushtubes to the correct length. The F-789 is too long and the F-790 pushtube is too short.
These two pushtubes are connected via a bell crank. The overall length is correct, but the bearings are screwed all the way in on F-790 and are probably too far out on the F-789. Tomorrow I will shorten the F-789 and lengthen the F-790.
F-789
F-789
Another view
Another view
Control stick is almost centered.
