Scott's Aircraft Build Logs
Date:  10-16-2013
Number of Hours:  1.00
Brief Description:  Static system
I had a Tech Counselor stop by the other day. He thought the lines from the static port needed to be a little shorter to ensure the port was the lowest spot in the system. An easy fix. I cut the right static port shorter which moved both lines up. I think I took an inch out of the line and then re-connected everything.
It moved the main white static line up slightly. Enough I was worried about it rubbing against the seat belt attachment point. You can see the seat belt attachment area in the upper left corner of image three. I made another clip which will get riveted when the skins go on permanently. The clip I added is also in the upper left. That clip pulls the line over sufficiently that it will not rub against any of the bolts in that area.
Left static port
Left static port
Right static port
Right static port
Static tubing clips
Static tubing clips
