I only had a couple of hours today. Initially I marked up the fuel lines for TS Flghtlights. I wanted to send them off this morning. But it is a holiday so the post office is closed. I will send them tomorrow.
Next was the rudder. I did not like the tension on the bolts as they went through the bearing. So I took the rudder off and realigned the bearings using a string and a weight. That got me pretty close, so I installed the rudder and started the micro adjustment of the bearings. It took more times than it should have, but I got it where I wanted it. Many more times; as in install the rudder, check the bolts, take the rudder off and adjust one or more of the bearings; repeat.
With the bearings aligned and the rudder installed, I noticed the new installation affected the rudder stops. Not much, but they both need to be shaved just a bit to get back to the 35 degrees of travel. I started on the left one and will fix the right one tomorrow.
