Scott's Aircraft Build Logs
Date:  8-21-2013
Brief Description:  Miscellaneous work - 02
Continued working on the static system. I managed to break a T connector for the static line, so I will be looking locally for a replacement. I found one that might work. I should have taken pictures but did not.
The static line runs under the longeron to the front of the aircraft. There are a few long runs without support so I fabricated two clips to support the line. The second image shows the clip on the line. It is too long, I just wanted to ensure it would work.
Static line clip
Static line clip
Static line clip
Static line clip
