Scott's Aircraft Build Logs
Date:  5-29-2012
Brief Description:  Forward tunnel cover
I spent two hours fabricating the forward tunnel cover attaching supports. This is the tunnel cover that goes between the seats forward of the electric flaps. Straight forward, so I made the first support bracket. Using it as a template I made an exact duplicate. Too bad I needed an exact mirror image instead. Good thing I can continue to build without it, I have ordered the replacement material.
I started to layout the first seat back. The initial steps were to cut various components to size. I did not take pictures, but I will when I fabricate the second seat.
