I finished all the work that I can completed on the outside of the fuselage. I mounted the F-709 bulkhead, it goes back by the tail. I forgot to take a photo so next time I go to the hangar I will take one. The last step on the outside was to fabricate a small angle that is used to hold the F-787 rib to the F-707 bulkhead. Too easy. Image two shows the angle clecoed in place. Drilling is completed but the riveting will have to wait until the aft top skins get riveted. They won't be riveted for some time so I can have access to run flight controls, wiring, pitot static lines, etc. to the back of the aircraft. Next is working on the baggage compartment and slowly moving forward for seats and other interioir projects.
