Scott's Aircraft Build Logs
Date:  6-18-2011
Number of Hours:  2.50
Brief Description:  Final stages of fuselage preparation
Finishing the final clean up steps to get ready to rivet the fuselage together. First I had to open up the hole under the tail to gain access to the retention bolt for the tail wheel spring. Then back to the dimpling process. Then back to the process of dimpling three big sheets; the two side skins F-770 and the front bottom skin F-772.
Tail wheel bolt access
F-772 bottom skin
F-772 bottom skin
F-770 side skins
F-770 side skins
