Spent a couple of hours over the last few weeks building the rudder pedal and brake pedal assemblies. Items left to complete are drilling the white mylar blocks to the lower longerons. I have already drilled the blocks, I need to mark and drill the longerons as well.. I decided on brake pedals for the left side only as I am the one primaryly flying it. I know the photos look like I installed them on the right side, but the fuselage is still upside down. The other task is drilling the holes for the brake master cylinders. They attach to the rudder pedal assemblies and the brake pedals. If you examine the third photo you can see the mounting tabs on the rudder pedal assembly (white tabs in the lower one third of the photo. The master cylinders attach at that point and a point yet to be drilled on the grey tabs sticking out at the top one third of the photo. After that is done the whole thing comes back out and gets set aside until the final assembly.
