Continuing with the center section I drilled, dimpled and riveted the 24 nut plates in place. The seat floor screws to the ribs so I can access the flight controls for inspections. After completing that task I clecoed the ribs to the bulkhead 704. The next step is to cleco the baggage floor ribs to the bulkhead 705 and then cleco 705 to the seat floor ribs. While all of that took just a few sentences to descibe it took much longer to complete. The most amount of time was spent getting the bottom skin clecoed to the ribs. Tomorrow I have a couple of straps to fabricate and then this can be drilled to size. I hope to start riveting the aft section next week when my wife is on spring break. I have run out of clecos.
