Scott's Aircraft Build Logs
Date:  3-9-2016
Number of Hours:  4.00
Brief Description:  Cowling - 05
Final finish on oil door access panel. Cowling is ready for UV Smooth Prime, a process I am delaying until it is consistantly warmer. The bottom cowling has a coat of high heat paint. All that is needed inside is the snorkle extension but I need to finish the carb air box first.
