Scott's Aircraft Build Logs
Date:  10-27-2015
Number of Hours:  5.00
Brief Description:  Firewall heat reflective material
I was very unhappy with the way the previous work on the firewall turned out. I just could notleave it on the aircraft. So I removed it all and started over. The images below show the new finished product. This material is not as fire resistant as the previous installation, but it is heat resistant. My goal was primarily to reduce the radiant engine heat and this product is designed to reflect up to 2000 degrees of indirect heat. It has a cross hatch finish so the images have a funny reflective look.
Back to building.
