Scott's Aircraft Build Logs
Date:  4-28-2017
Number of Hours:  2.50
Brief Description:  Wing tips and lighting - 01
Monday through Thursday not much gets done due to A&P school. I try to keep the ball moving along. Here is an update for Thrusday afternoon and Friday.
I needed to cut access holes for the strobe lights and the position lights. The strobe is a single 1" hole and the strobes needed a slot 3/8" by 2 1/14" as well as holes for mounting screws. Image one shows the reflector with the access holes cut. The clecos in the image are holding the reflector in place. Those will be filled with #6 screws. In image two you can see the left position light installed and temporarily connected to power.
