My good friend Doug Jones fly up to spend the day and help me work on my plane. I will have to return the favor many times over. We mounted the prop, it took too long because I forgot to put the aft prop bulkhead on. That meant taking if off and putting it back on. I am well practiced at mounting props now.
We placed the lower cowling in place to check the fit and I was surprised that it fit as well as it does. I originally fitted the cowling with a spacer I made as I did not have the prop. Seems to fit pretty well.
Doug worked on mounting the EGT probes while I worked on the avionics.
