Multiple updates in one. The baffling baffles continue to be a pain in the neck, but it is slowing coming together. One image does not really covey the amount of fitting that has occured since my slast update.
Advanced Flight Systems shipped my PFD so I spent time fitting it to the panel. The cut out I had done on the panel was slightly undersized (by a few thousands.) Using several tools I slowly managed to get it to fit. One of my concerns was the location of the Dynon network hub and it's location. I was afraid it would interfere with the cables that attached to the PFD. Much to my pleasure I found there was sufficient clearance for all the cables.
