Scott's Aircraft Build Logs
Date:  5-24-2016
Number of Hours:  4.00
Brief Description:  Wiring uipdate - 03
Wiring continues with more work at the fuse panel. I attached the terminal block for the left position light and taxi light to the inside of the most outboard rib. Also the three position lights wiring has to join at some point. I attached a terminal block for attaching the three wires to the power wire from the panel. A cleaner solution than splicing multiple wires.
Fuse panel
Fuse panel
Left wing lighting terminal block
Position light terminal block
