Continued wiring various systems. For some reason Windows 10 does not like portrait photos within this software, everything gets rotated to landscape. The first two images are rotated 90 degrees left (aircraft forward is down.) The first image shows the wire run forward of the subpanel on the pilot's side. You can see the firewall passthrough in the lower left corner. The brown heavy wires are for the CHT and EGT probes.
The second image shows the switch bank on the pilot's panel (again forward is down). It looks a little messy because I am just using twist ties to hold the wiring together. Eventually the wires will be laced Image three is another shot of the switch back, from left to right are the taxi, landing, position, strobe, fuel pump, autopilot and avionics switches.
