Scott's Aircraft Build Logs
Date:  2-12-2016
Number of Hours:  1.00
Brief Description:  Friday update - 03
Moved a few steps forward on the avionics stack installation tracks. Earlier I had cut the t-channel to size and clamped them in place to check the fit. Today I pulled the instrument panel so I could continue the work.
First I clamped both channels in the drill press vice and drilled the top and bottom holes using a #40 drill bit. Then I clamped them to the top of the instrument panel and drilled the panel to match the holes. Image three shows the back of the panel with the channels clecoed in place. I need to drill to size and bolt them in place. I plan on using AN507-6R13 machine screws but I do not have any that length (1"). I wil need to order those this weekend.
