Scott's Aircraft Build Logs
Date:  9-30-2015
Number of Hours:  3.00
Brief Description:  ADAHRS installed
After two weeks in Dallas and then time spent catching up with A&P school I finally got back to the aircraft. My wife and I worked on getting the dual ADAHRS installed. I thought this location would be a great place and provide some level of access for maintenance. May be a good place for operations but not so much for maintenance.
I am 6' and 210lbs. It is a tight fit for me to get into the back of the aircraft. Fortunately my wife was a better fit. She got most of the installation done but did not have the hand strength for final tightening of the screws. I used brass cap screws so we used an allen wrench to tighten them.
Currently the netwok cable hangs at an unacceptable angle so I need to address it. I will run it over the top of the ADAHRS mounting location. I still need to install the ELT.
Sometimes it pays to be smaller
Next time I will do this differently
