Attached the rest of the pitot / static / AOA lines for a test fit. If you look at the second image at the ADAHRS on the left side of the image you can see the spacer and longer bolt holding the ADAHRS in place. All that is left to install is the network splitter cable. That is one its way from Aircraft Spruce.
Other tasks completed:
1. Re-dimpled the aft skin and the associated bulkheads. The clecos going and and coming out have altered them slightly.
2. Purchased a slightly used Garmin 400W, I think it was used three flight hours so essentially new.
