Scott's Aircraft Build Logs
Date:  6-30-2015
Number of Hours:  2.50
Brief Description:  Canopy and GPS receiver
Had a few pin holes to fill on the canopy frame. Going to prime it tomorrow.
Drilled bolt holes and the wire access hole for the GPS receiver. After checking hole alignment with the GPS receiver I pulled the skin and riveted nutplates on the doubler. To ensure there was some adjustment available I enlarged the bolt holes slightly. The nutplates are centered so I can move the receiver sIightly when mounting it to the skin.
