Pulled the roll bar out for the last time to finish paint prep and paint. Next time it goes in it will be bolted and riveted in place.
Finished the last of the wire runs for the autopilot power, disconnect and roll data. Wiring now runs from the aft network hub the terminal block for the roll servo. Roll data and power and disconnect for both servos run to this terminal block. The roll data runs aft to the network hub, power (and ground) run forward to the panel, and disconnect runs to the stick.
