Scott's Aircraft Build Logs
Date:  2-27-2015
Brief Description:  Riveted bottom tip and attached chains
Moving on with more details completed. Riveted the rudder bottom fairing. After talking to a good friend that always has good advice I riveted this thing in place. Attached the tail wheel chains. The bolts that attach the cables and the chains are not torqued yet.
Riveted the bottom fairing
Chains attached
Chains attached
Used an eye-bolt
Used an eye-bolt
