Scott's Aircraft Build Logs
Date:  12-16-2014
Number of Hours:  4.00
Brief Description:  Fiberglass
I have been working on the fiberglass portion of the empennage, sanding all of the tips and finalizing their respective fit. Tomorrow I will start the lay up process. Once the process is closer to completion I will post some photos. Unless you want to see a lot of dust and sandpaper.
