Scott's Aircraft Build Logs
Date:  8-2-2014
Number of Hours:  4.50
Brief Description:  Big cut
I set up for the big cut last night. Measured everything and placed tape on the line I wanted to cut. But by morning I had changed my mind. I decided to trim the forward part of the canopy a little more before cutting the canopy in half.
This morning I ripped off all the tape and worked on identifying the curve I wanted from the sides to the forward edge. After about an hour I trimmed the foward edge and worked on creating a bevel across the front. The bevel needs more work and there is a little more that needs to be trimmed. Both sides lay flat but the middle of the forward edge still sits up about 1/16".
Satisfied that I was close to final on the forward trim I went back to the "Big Cut." I put the tape back down to identify my cut line. It had shifted slightly at the bottom but not by much. After getting everything ready I called my wife and she came over to help. Her had two jobs:
1. Watch my cutting angle and correct me if it looked off. She did!
2. Place tape down as I was cutting.
It was a non-event. I used my Dremel tool and a 2 1/2" cutting disc and cutting went smoothly and easily. I made two passes marking the material and then started cutting at one edge. I was really worried that I would crack the canopy. But in the end it was just another cut.
My lovely assistant
My lovely assistant
Taped as we cut
Taped as we cut
Aft section moved.
Aft section moved.
