Scott's Aircraft Build Logs
Date:  7-31-2014
Number of Hours:  1.00
Brief Description:  Re-routing strobe wiring
While waiting for the canopy to warm up for cutting I worked on the strobe wiring. I re-routed the strobe wiring in the right wing from the conduit to a location by itself. The ribs already had a hole drilled with a bushing in place courtesy of Vans. I decided to run the strobe wire to avoid any crosstalk with the servo wiring in the conduit.
