Scott's Aircraft Build Logs
Date:  7-26-2014
Brief Description:  ADAHRS tray
Finished fabrication ADAHRS tray. It is set to rivet to the J-channels and is within 1.0 degrees of all three axis. I have not riveted the rib in the front, I may need to trim some of it away when I run the lines to the ADAHRS.
