Scott's Aircraft Build Logs
Date:  7-21-2014
Brief Description:  Pitot Static runs for ADAHRS - 02
Here is where the pitot/AOA lines run under the Pilot's seat pan. There is one rib I will need to drill access for the lines to reach the fuselage wall. I am going to order a 90 degree fitting that will penetrate the fuselage wall with a quick disconnect on one side and a threaded connection of the other. Using the threaded connection through the fuselage skin I will attach another quick disconnect for the lines inside the aircraft. I am not crazy about having another connection within the pitot / static AOA system, but the strength of the 90 degree fitting is worth the risk. The only other connections will be at the ADAHRS, the pitot tube and static port.
Looking down at pilot's seat pan, front of aircraft is top of photo
Same location, forward is to the left
