Finished drilling the instrument attachment clips, there are two on each side. The photos show the end state, but it was quite a process of removing enough clecos to be able to get a long drill into the upper clips, putting everything together again, checking the fit, removing clecos and drill next hole, repeat. Now everything comes apart for dimpling, deburring and priming. Monday should be rivet day.
