Scott's Aircraft Build Logs
Date:  4-27-2014
Number of Hours:  2.50
Brief Description:  Front deck - 01
I finished cutting and filing the flutes into the support structure for the instrument panel. Then as I was drilling it to the panel I shaped it to the contour of the panel. Next were the two side pieces
Flutes cut into support
Drilled to the instrument panel
