Scott's Aircraft Build Logs
Date:  1-6-2014
Number of Hours:  4.00
Brief Description:  More fuselage projects
More small projects on the fuselage as I get closer to closing things up. The gusset in image one goes between the forward aft skin, the F-705 bulkhead and the J-channel stringers. As the skin is to be dimpled this needed to be countersunk and the aft edge needed to be beveled to allow a smooth transition under the skin. Using the countersink cage and a rasp file this went fairly quickly. After prepping for paint, I clecoed it in place with the fuselage skin to check aft edge and found a pre-punched hole in the skin that was not drilled to the J-stringer. Fixed that.
This was followed by dimpling the aft upper skin and painting a portion of the forward upper skin. The portion that was painted sits forward of the aft baggage compartment bulkhead. It is easier to paint it now.
Gusset
Gusset
Aft skin
Aft skin
Forward aft skin
Forward aft skin
