Scott's Aircraft Build Logs
RV-7
Fiberglass tips - 02
I also worked on the VS tip. While sanding I discovered either a void or a crack, not that it matters at this stage of the game. You can see the hole I ended up with as I sanded the void down to see its limits. Another task added to the list.
VS tip clecoed in place
From the left side
Void
Patrol Home
RV-7 Home
3527
346
134
Cowling
356
Finishing
133
532
227
Flight test
Fuel lines
730
Links
Polish
Pre-building
Stuff for sale
255
Wrap
