Worked in the hangar as long as my hands could take it. I must have dropped a thousand things, my fingers just would not grip. I did check the jam nuts on the HS and torque them. I reinstalled the elevators and installed the nuts. It was just too cold to work on torquing the elevator attaching bolts.
I installed the HS back on the aircraft and got the bolts, washers and nuts in place. Not torqued yet.
HS back on aircraft
Man what a bad torque seal job.. must be cold
Right side with a marginally better torque seal line
