I had a Tech Counselor stop by the other day. He thought the lines from the static port needed to be a little shorter to ensure the port was the lowest spot in the system. An easy fix. I cut the right static port shorter which moved both lines up. I think I took an inch out of the line and then re-connected everything.
It moved the main white static line up slightly. Enough I was worried about it rubbing against the seat belt attachment point. You can see the seat belt attachment area in the upper left corner of image three. I made another clip which will get riveted when the skins go on permanently. The clip I added is also in the upper left. That clip pulls the line over sufficiently that it will not rub against any of the bolts in that area.
