Yesterday and today I had a couple of hours after work to dedicate to the airplane. I fabricated a second rudder stop for the right side of the aircraft. Using the same block method to determine the correct distance from the elevator I removed just a slight amount of the stop. Both are now ready for riveting.
I also fabricated the two aileron stops. I need to drill the rivet holes and then go through the process of determining the correct amount of up travel. Maybe this weekend.
