Only had a couple of hours to work on the project today. More system work. First on the list was the Andair fuel selector valve. It is now in place waiting the fuel lines I order from TS Flightlines. They make teflon braided fuel lines for aircraft. As the fuel lines run through the cabin I wanted a higher quality line then I could create.
Next was to install the protective cover panel that sits in front of the fuel lines and just below your knees when seated in the aircraft. You can see the plans for the panel in image 2.
