Only had a little time to work on the project today. I focused on finishing the right tank fuel level probe and sealing the tank. I finished safetying the fuel pickup and reinstalled it in the fuel tank to check the probe placement. Everything is set for sealing. Tomorrow I will bend the fuel level probe for the RV-7 tank, attach it to the sensor and then seal the tank. Last step will be to pressure test the tank for leaks.
