Scott's Aircraft Build Logs
Date:  7-9-2013
Number of Hours:  0.50
Brief Description:  Aileron rigging
I wanted to double check the aileron rigging in comparison to the flap placement. I know I will want to do this one more time when the wings go on permanently, but before I put in the flight controls I wanted to know if this was correct. I clamped the aileron and flap together and then clecoed the "trail alignment" tool to the wing tip. The right wing is 1/16th above the line or a turn or two on the aileron pushtube.
Right aileron
Right aileron
Right flap fully retracted
