Scott's Aircraft Build Logs
Date:  7-7-2013
Number of Hours:  2.50
Brief Description:  Flap pushtube fabrication
I needed to fabricate two pushtubes to connect the flaps to the flap weldment. Cutting the tubing to size was done sometime ago. I have been pondering how I was going to ream the inner diameter to size so I can tap them. The bearings are threaded to screw into the pushtube.
So ...... I decided to take a large block of wood and used my drillpress to drill a hole in the center slightly smaller than the outside diameter of the tubing. Using my bandsaw I split the block. I used the block as clamp to hold the tubing in place during the reaming / drilling. Image one shows the tubing in the block and the block in my drill press vise. I used a second clamp to make sure the tubing did not spin while I drilled the inside diameter to the correct size. In the image it looks like the tubing is not aligned properly, but I think it is just the perspective of the camera. I spent a lot of time making sure it was properly aligned. After drilling I used the same block to hold the tubing in my bench vise while tapping. Image three shows the completed pushtube with the bearings screwed into place
Tube ready to be drilled
Tapping the pushtube
Completed
Completed
