Scott's Aircraft Build Logs
Date:  7-7-2013
Number of Hours:  1.00
Brief Description:  Wing work - 03
Several little jobs in the continuing saga to finish the wings. I broke the work into separate entries so there are more photos. First task was to drill the fuel tank attachment brackets. Needed 1/2" from each side, which was no problem. Drilled to 1/4".
Left wing fuel tank attachment bracket drilled
Right wing fuel tank attachment
