Scott's Aircraft Build Logs
Date:  5-29-2013
Brief Description:  Left wing
Managed to get to the hangar for two hours today. Worked on the left wing to get it ready for mounting. Tasks completed were; drillied, dimpled and deburred the last bottom skin to size; cut the flap hinge rod into two sections for mounting the flaps; adjusted the aileron pushtube to the correct length. I still need to torque all the bolts within the bell crank.
Bottom skin drilled, dimpled and deburred
Access area with nutplates riveted
