To get more photos in the build log, I have broken the work completed into a few short descriptions. Image one shows the adel clamp that holds the roll servo wiring in place. It is just a simple plate nut riveted to the rib. Image two shows the Dynon heated pitot tube control box mounted on a wing rib. I used small bushings to provide for a stand off from the rib itself. If you look at the screw head you can see the bushing. I need to replace the screws with something 1/2" longer. I do not have the thread exposure I want (minimum of two to three threads) and I want to add two Adel clamps to hold the wiring.
