Brief Description: Installing the manifold pressure line and sensor
I ran the steel-braided manifold pressure (MAP) hose from cylinder 1 to the firewall, connecting to a bulkhead fitting. Aft of the firewall, I used a 1/8" hose to connect the line to the Dynon Skyview EMS sensor (also attached to the firewall).
Thanks a million to Randy Richmond who had this length of rubber pressure hose, which absolutely solved my connection problem.
Running the MAP line from cylinder 1 to the firewall
Firewall pass-through, hose connection to the MAP sensor
